13 years agointerfacing Flex10k10 to CMOS
Hi There! Bit of a dumb question but can I directly interface a 10k10 to a 5v CMOS device or do I need to use pull-ups? From what I can tell it outputs *just* above 3.5v (on a 5v core/IO voltag...
13 years ago --- Quote Start --- For an all 5v system interfacing to CMOS components, do I select: TTL or LVCMOS/LVTTL? I'm guessing the latter as that would drive VOH up higher than 2.4v (TTL) but the 'low voltage' throws a wrench into that and is (perhaps?) not relevant? --- Quote End --- If its an all 5V system, then why would you suggest you are using VCCIO = 3.3V? :) I'm not sure that anything really changes in the I/O cells based on these selections. I recall that selecting between standards gives you more current drive options in some of the newer devices, but I don't recall the FLEX10Ks as having a lot of flexibility. It may be that these settings are more "you telling the tool about the PCB" rather than the tool using those settings to set a bit in the configuration bit stream. Either way, the I/Os are 5V tolerant, so you can try both. Generate a toggling signal and look at it with a scope for each setting. Cheers, Dave
