13 years agointerfacing Flex10k10 to CMOS
Hi There! Bit of a dumb question but can I directly interface a 10k10 to a 5v CMOS device or do I need to use pull-ups? From what I can tell it outputs *just* above 3.5v (on a 5v core/IO voltag...
13 years agoYou're right, I meant figure 19 :-) p47 is for 10k50v and 10k130v btw.
Maybe I'm making this more complicated than it is and it basically boils down to this question: For an all 5v system interfacing to CMOS components, do I select: TTL or LVCMOS/LVTTL? I'm guessing the latter as that would drive VOH up higher than 2.4v (TTL) but the 'low voltage' throws a wrench into that and is (perhaps?) not relevant? -Mux
