13 years agointerfacing Flex10k10 to CMOS
Hi There! Bit of a dumb question but can I directly interface a 10k10 to a 5v CMOS device or do I need to use pull-ups? From what I can tell it outputs *just* above 3.5v (on a 5v core/IO voltag...
13 years ago --- Quote Start --- The figures on page 19 specify either TTL or LVCMOS/LVTTL, assuming that VCCIO is 3.0 volts or thereabouts. --- Quote End --- You must have your reference page number incorrect. Page 19 has FLEX10K LE operating modes. --- Quote Start --- For an all 5-volt system interfacing to CMOS, which one should I select under the device settings? TTL or LVCMOS/LVTTL? Both seem to work fine but neither seems to be right :-) --- Quote End --- The tables on p47 might have what you want. Note how they indicate that VCCIO = 3.3V and that VIH(max) = 5.75V. This indicates that the inputs are 5V tolerant, and note 5 tells you that you can drive external signals onto these I/Os before the power is on. Cheers, Dave
