13 years agointerfacing Flex10k10 to CMOS
Hi There! Bit of a dumb question but can I directly interface a 10k10 to a 5v CMOS device or do I need to use pull-ups? From what I can tell it outputs *just* above 3.5v (on a 5v core/IO voltag...
13 years agoSo here's an odd follow-up question:
The figures on page 19 specify either TTL or LVCMOS/LVTTL, assuming that VCCIO is 3.0 volts or thereabouts. For an all 5-volt system interfacing to CMOS, which one should I select under the device settings? TTL or LVCMOS/LVTTL? Both seem to work fine but neither seems to be right :-) -Mux
