13 years agointerfacing Flex10k10 to CMOS
Hi There! Bit of a dumb question but can I directly interface a 10k10 to a 5v CMOS device or do I need to use pull-ups? From what I can tell it outputs *just* above 3.5v (on a 5v core/IO voltag...
13 years ago --- Quote Start --- Must've missed that. Got a page number? I measured ~3.5v, hence my question... Either way, the device I'm interfacing accepts anything > 2.2v, so I'm good :-) --- Quote End --- Here's a copy of the FLEX10K data sheet, I couldn't find a link on Altera's site. The information you want is in Table 19 on p44, and in Figure 20 on p46. The output high voltage depends on how much current your external device is drawing. If you really were driving a high-impedance input and were drawing no current, then Figure 20 indicate you should get a high voltage of 4V. Since you are getting 3.5V, either your VCCIO voltage is low, or your external device is drawing a few milliamps. As you comment, your interface logic levels are compatible, so you're fine. Cheers, Dave
