13 years agointerfacing fft megacore ip with nios processor
i need to interface altera's fft ip core with nios processor.fft core is implementing 16k fft.To interface this fft core with scatter gather dma i made following 'manipulation' of fft core. wha...
13 years agoI'm not sure, I don't have the v9 tools installed any longer since they are four years old. You could probably check the documentation that you have already read again and maybe it will say?
If it doesn't, then the tool you might be using might be called "SOPC Builder" and it's (very similar) documentation is here, and you should re-read it again: http://www.altera.com/literature/ug/ug_sopc_builder.pdf (pages 3-3 to 3-5 for starters) Good luck!
