13 years agointerfacing Altera Cyclone 3 FPGA to a peripheral using UART
Hi everybody, i'm working in my 1st project in FPGA Altera Cyclone 3 (EP3C25) and i have to connect a peripheral that have only an UART interface to my FPGA. which interface of the FPGA board i...
13 years ago --- Quote Start --- From what you said I guess you are targeting a CIII starter board: then you can definitely use the HSMC connector. Any internal signals implemented in fpga logic can be routed to any fpga I/O pin: so you only need a pcb trace going from fpga pin to a board connector pin. As I remarked before, you possibly need a buffer (TTL or RS232) to interface the wireless module: read the module datasheet and find out if those uart signaling levels are compatible with fpga I/O ports, which are basically LVTTL. Also check if the wireless module uart requires handshake signals (rts / cts) besides tx and rx: in this case you'll need 4 lines for the interface, 2 inputs and 2 outputs. --- Quote End --- thanks a lot cris that's exactly what i mean : i have to use the HSMC connector. the signaling levels are compatible and for wireless module uart is composed from 1 tx and 1 rx so it will be directly connected to the HSMC.
