15 years agointerface with niosII processor
Hi, Is it possible the interface of ram IP core (from megawizard plug in manager) with niosII processor and VHDL as target HDL. I have generated NiosII processor with 4K of on chip ram.Fo...
15 years agoDo you want a memory bloc that can be both accessed from outside and from the Nios CPU? In that case you will need a dual port RAM, not a "RAM-1 port", have to write some HDL to connect one of the ports to an Avalon Slave interface, and use the whole as a new SOPC component.
If you just one a single port RAM connected to the Nios CPU then don't use the megawizard. Just add an on-chip memory component as fheineman explained.
