RShal4
7 years agoIntel's UART IP miss bytes in high baud rate ?
Hello, We encounter loss of bytes on a read from serial. This happens in high rate (912600), we see that the bytes are getting lost. We verified that the application which reads bytes, is effecti...
- 7 years ago
We eventually moved from the simple IP's of UART (which only have 1 byte!) to the FIFOed avalon uart.
This seems to fix the problem.
Thank you,
ran
FawazJ_Altera
7 years agoHello,
May I know what is the frequency you used for this UART IP?
You need to maintain the Divisor formula as seen in page 126
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
RShal4
7 years agoHi,
Thank you,
ran
