intel Cyclone V e , FPGA not reconfiguring to new flashed Image in EPCQ flash
- 4 years ago
Hi, for CRC error, i think it could be due to the incorrect bitstream / bitstream order when loading it into the QSPI flash. I would suggest to select the appropriate data format when generating RPD file. You can select little endian for it. Otherwise, you need to do bit reversal.
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Hi
Iam working with custom board with intel Cyclone 10 LP (10cl080yu484c6g) FPGA and Active serial device is EPCQ16A. here I am facing problem for generating JIC programming file for active serial configuration, I am getting error like “Size of file(s) in EPCQ16A exceeds memory capacity“. for this I made compress and I generated JIC programming file but it not programming into the active serial configurable devise (EPCQ16A). always Iam programming through JTAG connections and USB Blaster but Iam getting failed.
for this my hardware configured MSEL pins value is (1101).
ASDO, ASDI, AS nCS, AS DCLK pins are properly connected.
please suggest me solution.
thanks & regards.
D. Srikanth
