SnehalB
4 years agointel Cyclone V e , FPGA not reconfiguring to new flashed Image in EPCQ flash
we are using intel cyclone v e device with EPCQ connected serial flash. we are using two IP core in our design 1st generic serial flash controller IP core for flashing EPCQ256 with .rpd image ...
- 4 years ago
Hi, for CRC error, i think it could be due to the incorrect bitstream / bitstream order when loading it into the QSPI flash. I would suggest to select the appropriate data format when generating RPD file. You can select little endian for it. Otherwise, you need to do bit reversal.
YuanLi_S_Intel
4 years agoHi, for CRC error, i think it could be due to the incorrect bitstream / bitstream order when loading it into the QSPI flash. I would suggest to select the appropriate data format when generating RPD file. You can select little endian for it. Otherwise, you need to do bit reversal.
