SnehalB
4 years agointel Cyclone V e , FPGA not reconfiguring to new flashed Image in EPCQ flash
we are using intel cyclone v e device with EPCQ connected serial flash. we are using two IP core in our design 1st generic serial flash controller IP core for flashing EPCQ256 with .rpd image ...
- 4 years ago
Hi, for CRC error, i think it could be due to the incorrect bitstream / bitstream order when loading it into the QSPI flash. I would suggest to select the appropriate data format when generating RPD file. You can select little endian for it. Otherwise, you need to do bit reversal.
SnehalB
4 years agohi how can we read back flash besides flash controller IP, is there any utility or method to read a FLASH via FPGA using jtag or serial interface.
thanks & regards!
Snehal B
