Intel® JHL7440 Thunderbolt™ 3 Controller (QE17863)
Could you confirm that PN: JHL7440 SLMJ2 is correct for tape and reel version?
I'm also looking for RoHS 3 CoC file of this controller.
Will you be able to help me?
Thank you!
Hello , do you have any updates ?
It seems that I have the same issue.
I want to build a device using the JHL7440 SLMJ2
TBT controller. However there is no Pin-out or EDA and CAD files avalible online. I have already texted Mouser el. about this issue ,
but I've letted them know that I'll contact you first.
Please , are this pin-outs marked as confidential and can I wiew them in Quartus EDA software?
If so , can I reach the same results with Cyclone FPGA and a bit of Verilog programming , or PCIe and USB3.2 XHCi
perhaps if you got any bridges or PHY ?
Also , considering this situation I want to connect GPU using TBT as an endpoint device and have a laptop that has already
TBT built inside can the TBT interface auto-detect PCIe ? I looked at your datasheet and in layman's term it seems to be
simplified to an extreme stupid simplicity that it's basically just a switch between USB , PCIe and DP.
Also got any recomendations for PCIe and USB switching device ? I looked for Broadcom and they seem nice to me
Please reply ASAP , thank you
Thank you in advance
Ondrej
EDITED : I'm ataching datasheet from mouser el. Here is the link https://www.mouser.sk/ProductDetail/Intel/JHL7440-S-LMHZ?qs=MLItCLRbWswTHfM8e%252BJB6w%3D%3D
