13 years agoincrease TSE throughput issue
Dear all, My board: DE2-115 Cyclone IV E I've managed to run Web server template which is available with board by using: -TSE 10/100/1000 Gbps -Nios cpu Economic -50MHz clock. - and ...
13 years agoafter code optimizations you have to play with TSE MAC fifo's depth, NIOS chaches dimensions, clock frequency, but don't expect do gain and order of magnitude in data troguhput.
Which way did you measure the troughput? Using Web Server Template Application? Keep in mind that web-server gets website data from the Flash memory, I wonder if this couldn't significantly affect the overhead while fetching data.
