13 years agoIn-System Programming with Cyclone III
Hello, I have a custom board that uses the Cyclone III (EP3C40 - 240 pin) FPGA. The board has two headers for connecting to the ByteBlaster II. One of the headers is used for JTAG configuration...
13 years agoInteresting.. There is no series termination or 0-ohm resistor but I almost wonder if perhaps I botched my soldering job of the EPCS device. I'll also take a look at another test point for the signal, like the pin of the FPGA (pin 23 for DCLK on this one) just to check if there is a more clear signal at the transmission side. I'd think that the reflection will still be apparent at this end since the trace is pretty short, but I'll have a look there anyways.
I guess a couple of things to post back with once I get back home to have a look. Thanks again for suggestions.
