13 years agoIn-System Programming with Cyclone III
Hello, I have a custom board that uses the Cyclone III (EP3C40 - 240 pin) FPGA. The board has two headers for connecting to the ByteBlaster II. One of the headers is used for JTAG configuration...
13 years agoHow do you set the MSEL pins to 0 or 1? They need to be hard wired to ground or 2.5V, not controlled through a register or a microcontroller, as the FPGA could get a wrong reading on the MSEL pins when it starts up.
Did you try to see with a scope if the FPGA is trying to read the flash when it starts? What are the levels on the nSTATUS, nCONFIG and CONF_DONE signals?
