16 years agoImport the OpenCV (image proccessing) C/C++ library in NiosII
Hello
I will make a image proccessing project, camera tracking. Can I import the OpenCV library in NiosII? - http://opencv.willowgarage.com/wiki/fullopencvwiki - http://opencv.willowgarage.com/wiki/ - http://opencv.willowgarage.com/wiki/eclipse Thank you Antonio6 Replies
i didn't compile opencv library but i compiled CImg.h library.
so you can try using CImg.h it's also good. but if you want opencv you can try to compile it. good luck - Altera_Forum
hello Antonioa et Aydi
are you succeed in import opencv Library in NiosII or powerpc??? please if you succeed on help me thanks - Altera_Forum
Hello Antonio,
I am currently working on benchmarking opencv on NIOS II. I was wondering if you had any luck with porting it to NIOS. If so would you be able to share code or point me in the right direction. Thanks - Altera_Forum
hello,
please i want to know if i can import the library opencv_b4a with nios2 or powerpc or stratix3. i have an FPGA board. thanks an advance. - Altera_Forum
You could start by compiling the cxcore and cv libraries, discard the highgui library. It's required a very careful modification of Makefiles. I guess it'll be easier if your system is uCLinux based, and maybe Makefiles modification is not required, check CV install guide.
