15 years agoImplementing ROM - which FPGA to use?
Hi all, I need to implement 5 look-up tables (for 5 DACs), with a total of ~800Kbits. I built a simple rom (didn't use a mega-function) - an entity with address and data pins and an internal ar...
15 years agoAn uncompressed configuration image will always require the size specified in device handbook. If you enable compression in the device configuration respectively in Programming File Conversion tool (for indirect JTAG programming), the required size will be reduced depending on the device utilization.
