15 years agoImplementing ROM - which FPGA to use?
Hi all, I need to implement 5 look-up tables (for 5 DACs), with a total of ~800Kbits. I built a simple rom (didn't use a mega-function) - an entity with address and data pins and an internal ar...
15 years ago --- Quote Start --- My question is whether there is a way to know which flash memory should I use. --- Quote End --- KAZ has answered the question clearly. The maximum configuration image size for each FPGA type is written in the device hardware manual. I guess, you intend to use serial flash (Altera EPCS or compatible), but you didn't explicitely tell. 16 MBit is good upto EP3C55, see table 9-3, configuration file size. Additional memory space may be required for designs involving soft processors.
