15 years agoImplementing ROM - which FPGA to use?
Hi all, I need to implement 5 look-up tables (for 5 DACs), with a total of ~800Kbits. I built a simple rom (didn't use a mega-function) - an entity with address and data pins and an internal ar...
15 years agoIn the megawizard, you will have a choice (to choose which memory block size to choose from or set it auto if available,it also gives you entry for path to initial values or rom values i.e. a mif or hex file).
What is that flash memory for? external for software? then it depends on your software size.
