10 years agoImplementing a table
Hello all, I'm trying to implement a table with stored switching angles for an inverter on to an FPGA. I'm a beginner so I'm having a lot of trouble figuring this out so please bare with me. H...
10 years ago --- Quote Start --- This is going to be a look-up table (LUT) - this is just a ROM. It is basically a rom where you provide the address (modulation index) and you get the output data (angles) It is quite straight forward to code in VHDL and there are plenty of examples out there. --- Quote End --- Thank you, this was what i thought i needed to use as well. A follow up question though, do i need to use 9 of these blocks in parallel or can it all be done with one, and also how could I test the functionality of this (with a 7-segment display maybe as output)?
