13 years agoImpact of .sdc-Constrainsfile to Fitter
I have a basic understanding problem of meaning of .sdc-Constainsfile for Quartus Project.
First I understand is, that I can define Timing-Constrains in .sdc-File, that I can check with Timequest if met. Second what I not now, is how Fitter of Quartus reads statements of .sdc-File as requirement and take more effort to reach this requirement? Knows anyone how .sdc-File effects Fitter Effort? Kind regards Gerhard2 Replies
Quartus uses the .SDC file. It will generate a warning if you do not include one.
In the Quartus GUI, look at the setting: Assignments->Settings, Category: Fitter Settings. There is a section called "Timing-driven compilation". You can check the "Optimize multi-corner timing" to tell Quartus to use the .SDC file at all process-voltage-temperature (PVT) settings, otherwise it just meets timing at the nominal speed grade setting. Cheers, Dave - Altera_Forum
What I know about that is that Fitter uses the informatio provided by sdc file to guide it to place and route the entities in a way to attend the time constraints.
