10 years agoI'm implementing a Math Equation on my FPGA, am I following the right methodology?
Dear friends, This is my first project ever in FPGA. I'm implementing a Math Equation over a list of numbers (data) which range from 0 - 255, one by one, data can contain 100 or 10.000 or ...
10 years ago --- Quote Start --- That is one way to do it. But can you load any data you want into the memory without re-compiling the system? Another method would be to load the data serially from a PC, maybe via UART? then you could process as much real time data as you wanted. --- Quote End --- I want to thank you Tricky for your patience, so what do you mean by "without re-compiling the system"? One observation is that I should be able to load different sets of data (different photos, same resolution, same characteristics), so I guess you mean that, I wish to be able to analyze different set of datas. That method that you mention, how to do this? any specific tool to use? wouldn't be that a Qsys sytem also? Is the ARM play any part on this?
