10 years agoIllegal I/O standard
Hi, When I compile my design I end up in the following error: Error (169092): Illegal I/O standard 3.3 V Schmitt Trigger for pin <SCL> -- I/O standard not supported by output pins in target d...
10 years agoHi,
according to the MAX 10 device datasheet, Schmitt trigger inputs are supported on all pins ("max 10 devices support schmitt trigger input on all i/o pins", see section "dc characteristics"). I think the problem is that you are trying to select Schmitt trigger characteristics for an output pin. A Schmitt trigger only makes sense for inputs. I don't know though how this behaves when your pin is bidirectional. "SCL" sounds like an I2C clock pin; if you want to support clock stretching, that pin would have to be bidirectional ("inout" in VHDL). I would expect that you can configure such a pin as Schmitt trigger. Best regards, GooGooCluster
