10 years agoIdentify EPCS and EPCQ
Hi, We use remote programming. How to identify if the memory is EPCS or EPCQ ? They use different opcodes for identification, is there a way to identify if the memory is EPCQ or EPCS ? ...
10 years ago --- Quote Start --- I think that EPCS don't support (except 128) "Read device Identification" and EPCQ doesn't support "Read Silicon ID", am I correct ? --- Quote End --- Correct. --- Quote Start --- What do they return if "Read silicon ID" is used for EPCQ and "Read device Identification" for EPCS ? --- Quote End --- The DATA (EPCS) or DATA1 (EPCQ) signal is high-impedance when it's not driving. This will be the case when you issue an instruction they don't recognise. What you read back will depend on your design. If you have a convenient pull-up (which is, probably, not likely to be the case) you'd get something predictable - 0xFF. However, even without you're unlikely to read back a valid device or silicone ID from a device that doesn't support the command. So, you should be able to distinguish these parts using these two commands. Happy New Year, Alex
