13 years agoidcode for stratix5 device
Hello! I'm beginning to use board HiTechGlobal HTG-S5-PCIE based Stratix5. When Quartus II Programmer executed the command Autodetect is detects the FPGA as UNKNOWN_029FB0DD. What chip Stratix5 is of...
13 years agoRead the HiTechGlobal literature, eg., they should have a handbook or user manual for your board, that documentation should have the FPGA part number. Use that part number to locate the IDCODE in the Stratix V Handbook.
Then use the Quartus JTAG debugger to read the IDCODE. Are you connecting to the board with a USB-Blaster or does it have an on-board USB-Blaster? If you are using an external USB-Blaster, try using another one, perhaps you are having JTAG signal integrity issues. Cheers, Dave
