13 years ago
I want to use clock oscillator...
Hi. I have DE0 board and it has 50MHz clock oscillator.
I want to make a digital clock, and I know How to change 50MHZ to 1Hz,
But I don't know how to make the 50MHz oscillator start.
When i push the button or swich, I want to make the 50MHz oscillator start to work.
How can I do that?
I have user manual , but it doesn't tell me how to do that.
    est_reg, est_prox are current and next value of the state register of the state machine. You can declare this way:
    architecture blablabla of...
    type estado is ( ini, contando,.. ); -- only 2 states. I don't know if your design need more.
    signal est_reg, est_prox : estado;
    begin
    -- here starts the code, process, etc.
    As you see, contando is a state of the state machine.
    Thanks buddy! but.. what is the est_prox, est_reg, contando?
    Try to use your clock to create a ramp... that's how you can slow down the clock.
    to slow down your clock:
    process(n_clr, clk)
    begin
    if(n_clr='0') then
    cont_reg <= ( others => '0' );
    elsif(clk'event and clk='1') then
    cont_reg <= cont_prox;
    end if;
    end process;
    cont_prox <= cont_reg + 1 when ( cont_reg < 50000000 and cont_on='1' ) else
    ( others => '0' ) when ( cont_reg = 50000000 and cont_on='1' ) else
    cont_reg;
    tick_1s = '1' when ( cont_reg = 50000000 ) else
    '0';
    to start your clock with a button make a state machine:
    process...
    if(n_clr='0') then
    est_reg = ini;
    elsif(clk....
    est_reg <= est_prox;
    end....
    process(...
    est_prox <= est_reg;
    cont_on <= '0';
    case est_reg is
    when ini =>
    if (button ='0' ) then
    est_prox <= contando;
    end if;
    when contando =>
    cont_on <='1';
