17 years agoI want to know the max speed of NIOS ii based on cyclone iii EP3C120N780C
I have a DK-DSP-3C120N KIT,the NIOS II clock can not exceed 100mhz.The highest speed of NIOS II /f is now just 100mhz.The C program always dead when the clock exceed 100mhz.I want to working at least...
16 years agoThank you,BadOmen!
Your codes are working.All unconstrained paths has been cleared! After Report All Summaries,the report pane of TimeQuest display 2 red warning: 1)Summary (setup) Clock slack end point TNS inst|the_altpll_0|altpll1|pll3|clk[0] -1.167 -131.807 2)Summary(recovery) inst|the_altpll_0|altpll1|pll3|clk[0] -5.900 -78.992 To constraining PLL,I place this code in the .sdc file: create_clock -name {clk_50mhz} -period 20.000 -waveform { 0.000 10.000 } \[get_ports {clk_50mhz}] derive_pll_clocks derive_clock_uncertainty The input clock of the altpll is 50mhz,and output clock is 166.7mhz I don’t understand where the negative slack come from,and how to eliminate it. After compilation ,I receive 3 critical warning(Timing requirements not met) because of this.
