15 years agoi need an FPGA kit with transceiver's for the purpose running LTE layers on it ...
please provide me with some suggestions ASAP.
15 years ago --- Quote Start --- i have developed the lte layer 2 which works for the frequencies between 3 MHZ to 20 MHZ ..... so i need to implement this all layer coding on FPGA with one transceiver as a base station and othr as an user equipment --- Quote End --- You still haven't explained what the operating characteristics of your transceivers are. I've never looked at LTE requirements, and many others with transceiver experience may not have either. I am sure Altera has some application note, or MegaCore users guide, explaining some of this stuff. Try and have a look at their documents. If you can explain what you want to do with the transceiver in terms of clocking, encoding requirements (8B/10B ), input/output data widths and rates, number of lanes, etc., then we can suggest FPGA families. Cheers, Dave
