i have installed max+plus II baseline 10.2 on my system. Also i have a software guard. I need to target my design onto EPF8636 device. But i find that it is not listed
Can you try to install other version of max+plus II on the following link to check whether it support the following devices
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/legacy/maxplus2/upd-maxplus2_index.html
Joanne
- kprab37 years ago
Hi, I tried to access through the link. The download just does not start!.. Probably the content is no longer accessible.. Regards, Prabhakar- JoanneSinY_L_Intel7 years ago
I found the ddf file is available in this two web page, could you try to install ?
http://magnetfox.info/download/3533506/max-plus-ii-10-0-polnaya-versiya
https://www.monova.to/C6B52192700180C30C01C83B5E17251A27C10C1C
Joanne
- kprab37 years ago
Hi, I could download the update files for maxplus + II baseline 10.2 and now the required device (epf8636) is appearing in the list. However during compilation , I get an error “cant open file c:\maxplus2\f8636160.ddf” And I do not find that particular file in the said directory. Please suggest … Thanks and regards, Prabhakar - JoanneSinY_L_Intel7 years ago
Yes, no every version of the software can be accessible on the above link. But version 9.2 is able to be installed on the link above.
https://www.intel.com/content/www/us/en/programmable/downloads/thank-you.html?swcode=WWW-SWD-MP2-902-PC
Btw, I checked max+plusII version 9.3 and it supports the following device FLEX8000
Joanne
