I am getting a hold violation using the on chip flash ip. What can I do to resolve this issue?
0.000=relationship, 0.478 = skew. 1.428=Data Delay
Here's the bulk of the sdc file. Of course, I just rerouted it and didn't get the hold violation. This morning, all the routes had a hold delay.
# Create the Input Clock from the external oscillator
create_clock -name {clk25mhz_i} -period 40.000 [get_ports { clk25mhz_i }]
# Create Generated Clock
derive_pll_clocks
create_clock -name clk25Virt -period 40.000
# Set Clock Latency
# Set Clock Uncertainty
derive_clock_uncertainty
# Set Output Delay
set_output_delay -clock { clk25Virt } -max 0.0 [get_ports {motor_h1_o motor_l1_o motor_h2_o motor_l2_o}]
set_output_delay -clock { clk25Virt } -min 0.0 [get_ports {motor_h1_o motor_l1_o motor_h2_o motor_l2_o}]
set_output_delay -clock { clk25Virt } -max 0.0 [get_ports {buzz_o }]
set_output_delay -clock { clk25Virt } -min 0.0 [get_ports {buzz_o }]
set_output_delay -clock { clk25Virt } -max 0.0 [get_ports {led_blank_o led_data_o led_latch_o led_sclk_o}]
set_output_delay -clock { clk25Virt } -min 0.0 [get_ports {led_blank_o led_data_o led_latch_o led_sclk_o}]
