15 years agohow tooutput a high speed clock
I need a clock to control high speed AD.But I measure it with oscillograph finding it is very bad so that AD can't work. thank you very much
15 years agoYou can use an external clock source that is programmable.
An external clock source that is programmable? Can you give a example(the chip's name )? As you know,I am designing an oscilloscope so the sample rate Varies greatly. I design divider that is programmable using FPGA to control ADC clock. Equivalent sampling is to use low-frequency sampling high-frequency signals. I use the sequential sampling technique. sampling a point a cycle of signal, and delay a slight time(slight delay determines the sampling rate ). I use the 200M counting clock signalto get signal's period. And I design a state machine get the clock to control AD.
