9 years ago
How to use LVDS pins on CycloneIV bank8 for receive?
I need to configure LVDS receive pins on bank8 of cycloneIV. It is dedicate to LVDS receive but not LVDS TX. I saw on handbook said on bank8 the LVDS do not support true LVDS for tx and need to addtinonal resistors externally. How about LVDS receive of bank8? Is a 120ohm resistor in between of diffio_p and diffio_n able to implement LVDS recevie on bank8?
Dose it mean on all banks of cycloneIV, the LVDS receive just need such a 120om resistor no matter true LVDS or not?
    That's correct - for Cyclone IV. Newer families - including Cyclone V - have dedicated Tx & Rx pairs. So, that wouldn't be the case.
    If in doubt, try it. Run it through Quartus with the pin assignments you want. Quartus will tell you if it's invalid.
    Cheers,
    Alex
    Thanks for the quick reply.
    Another I am not quite sure : Are all the LVDS pairs bidirectional? For example, DIFFIO_T8p and DIFFIO_T8n pair is able to be configured as both LVDS rx and LVDS tx(emulate LVDS). Becasue of it is DIFF'IO'.
    Is my understanding correct?
    Yes for RX you need only termination resitor and handbook states that it should be 100ohm.
