18 years agohow to use audio codec of altera de2
We r doing a project called "direct digital synthesis" using altera de2 board...we have got the sine output in the signal tap2 analyser...now we have to use codec to get the analog display in...
18 years agoI also think, that the Terasic demonstration projects should be better documented, particularly when considering the educational target of the boards. The alternative of reusing the code is to write it from the scratch. Personally, I would prefer this way, also using VHDL. But unfortunately, I'm not using the board at present and can't provide any code. May be other users can?
