13 years agoHow to trigger the Reset signal
Hi, Because the FPGA development board is installed on a remote machine, I have no access to the physical buttons on board, is there any other way to raise the reset signal after downloading th...
13 years agoI presonnaly add in my vhdl code a ram of 1 bit that is pre-loaded with the value 1.
A little process checks if the value is 1 (so after programming or power cycling from the epcs128), if the value is 1, I assert the internal reset of my design and clear the bit in the ram.
