13 years agoHow to trigger the Reset signal
Hi, Because the FPGA development board is installed on a remote machine, I have no access to the physical buttons on board, is there any other way to raise the reset signal after downloading th...
13 years ago --- Quote Start --- I presume you are talking about JTAG indirect programming of AS or AP configuration memory? "Initiate configuration after programming" is an option that can be either checked or unchecked in the programmer tool. The initiate through JTAG is equivalent to asserting nConfig in hardware. --- Quote End --- Thanks FvM, could you specify a bit more on this? I see there's this "Initiate configuration after programming" option in the programmer, but what else needs to be done in order to raise the reset signal after programming? "The initiate through JTAG is equivalent to asserting nConfig in hardware" I figure out nConfig signal begins the configuration cycle, but I don't understand the connection between this nConfig signal and raising the reset signal. Could you please explain more? Thanks
