13 years agoHow to trigger the Reset signal
Hi, Because the FPGA development board is installed on a remote machine, I have no access to the physical buttons on board, is there any other way to raise the reset signal after downloading th...
13 years agoI presume you are talking about JTAG indirect programming of AS or AP configuration memory?
"Initiate configuration after programming" is an option that can be either checked or unchecked in the programmer tool. The initiate through JTAG is equivalent to asserting nConfig in hardware.
