13 years agoHow to synchronize a PLL with a clock signal
In my design I require there to be a 100 mhz clock signal and a 50 mhz clock signal. I have an 50 mhz clock source so I decided to use a PLL to convert it to a 100 mhz clock. The only issue I have is...
13 years agoHow would that be done? I am using a megafunction and the closest thing I can find is Source-Synchronous compensation mode. Is that the mode that I need to enable?
