9 years agoHow to square a fixed point number?
Assuming I have a 16 bit fixed point number that needs to be squared, how should this be implemented? The number format is Q2.14. Squaring it shall produce a result that is 32 bits instead a...
9 years agoFvM you said:
"The simplest way to do the result scaling and saturation is to use IEEE fixed point package." Are you talking about the fixed_pkg? Is it synthesizeable? How exactly does it help here? I mean if I am going to use a multiplier IP block from the IP catalog to do multiplication, the top level ports of it are std_logic_vector. So how would the fixed_pkg help in that?
