18 years agohow to resolve JTAG problem
Hello, I am using USB-Blaster to connect to the board.
I am trying to run a sample program from DEVKIT v1.0.1 on EMIF. It is said on the website that this example should work with my EP2C70 family(this is what I have), but the example, when I want to program it onto my board under "Device" field says: EP2C35. This results in the following error: "Error: Can't configure device. Expected JTAG ID code 0x020B40DD for device 1, but found JTAG ID code 0x020B60DD." Is there a way to resolve this problem? Thank you very much3 Replies
Sorry, did not realize.
So, all I have done is: switched the "Device" in the settings window to the device I needed and recompiled for the proper Top-Level entry. It resulted in a proper .sof file for the needed device and was further on programmed on the hardware. Simple... I am just totally new in this busnees :) - Altera_Forum
You might want to tell others how you did it.
Problem is resolved
