10 years agoHow to reset a ram?
Hi, in my vhdl design I got a ram signal R then I try to test it against A with "if A > R then..." but R starts with a 'X' value so the test is not working. What could I do to solve that problem? ...
10 years agoTo reset the RAM in modelsim to get rid of x you could use the mem load command:
mem load -filltype value -filldata 0 -fillradix symbolic /tb/the_ram_to_be_resetted/altsyncram_component/m_default/altsyncram_inst/mem_data or emulate random data: mem load -filltype rand -filldata 0 -fillradix symbolic /tb/the_ram_to_be_resetted/altsyncram_component/m_default/altsyncram_inst/mem_data In a real design you need a memory initialization file. If not supplied or not found Quartus sets all initial values to 0. This behaviour is may depending on the type of FPGA.
