10 years agoHow to reset a ram?
Hi, in my vhdl design I got a ram signal R then I try to test it against A with "if A > R then..." but R starts with a 'X' value so the test is not working. What could I do to solve that problem? ...
10 years ago --- Quote Start --- As I'm using M9K I know the signal is starting at 0 but Modelsim doesn't know and says it's X. Is there a way of making the simulation start with 0? --- Quote End --- But you dont know the ram will start up at 0 (memory contents at startup will be random unless specified). Hence why you get an X in simulation - ie unknown. You need to write something to the address to get a known value.
