10 years agoHow to reset a ram?
Hi, in my vhdl design I got a ram signal R then I try to test it against A with "if A > R then..." but R starts with a 'X' value so the test is not working. What could I do to solve that problem? ...
10 years ago --- Quote Start --- Hi, in my vhdl design I got a ram signal R then I try to test it against A with "if A > R then..." but R starts with a 'X' value so the test is not working. What could I do to solve that problem? Thanks. --- Quote End --- for power up conditions look at section 3-14: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram_rom.pdf for reset, you can only reset output ram registers if available
