15 years agoHow to reduce the area of my design?
Hi all, I'm doing an FPGA design with Stratix 3; And our design doesn't fit into a single chip. Our FPGA has 38000 Combinational ALUTs and 38000 dedicated logic registers; Our design tak...
15 years agoif your design is so much exceed your FPGA, i don't think that different compilation guidelines would solve the problem.
I think that you should think creatively about logical reduction, i.e. if you have few instances of the same module, maybe you can create single module which operates in time sharing? or use the FPGA memory as ROM tables instead of complex logic?
