15 years agohow to realize demodulation module in FPGA
hi everyone, i want to realize demodulation module in EP2C35 with verilog code,the frequency of carrier wave is 10KHz, and the frequency of modulation wave is 2.5MHz. what method or algorithm is...
15 years ago --- Quote Start --- Are you generating the 10kHz signal on the 2.5MHz carrier? If so, it will make your system design easier if the FPGA processing the receiver channels uses the same reference frequency as the transmitter. Out of interest, why is the ultrasonic bandwidth only 10kHz? That seems like a very narrow bandwidth (relative to the sonar and medical ultrasound devices I've used). --- Quote End --- Maybe I didn't express clearly. 10KHz isn't the bandwith of ultrasonic signal,which is the frequency of envelope of modulated signal.
