14 years agoHow to program them when the chain have CPLD and FPGA?
Hi, all I have build a system that must use one CPLD and another is FPGA. Its connection is listed as attachment. https://www.alteraforum.com/forum/attachment.php?attachmentid=5408 ...
14 years ago --- Quote Start --- what version are you using and what are you doing to run into the bug? what happens if you double click the <none> in the File Column and FPGA row? --- Quote End --- The QuartusII version is 9.1 SP2. I am going to program the JTAG chain by adding config file to device and then the bug happen. when i double click the <none> one window popup to select the config file, but the bug take place when i select the pof or jed and click ok. Hope your further help, this problem has blocked me some days. Thank you!
