How to program EPCQ4ASI8N for an old Cyclone FPGA
This may help anyone switching from EPCS1 to EPCQ4A. (and presumably from any compatible EPCS* part)
We have a legacy design using a Cyclone II EP2C5T144C8N, originally with an EPCS1 and .pof file generated by Quartus II V12.1.
The EPCQ4A fitted and programmed fine using the original .pof file with the Quartus Prime Standard Edition (V16.0.0) standalone programmer. We used an Altera USB Blaster Rev. C cable, and programmed in Active Serial mode.
I am migrating from EPCS1 part to EPCQ4A part, here am facing the problem while am trying to load the .pof file of EPCS1 device while programming to EPCQ4A. Can you tell me the procedure to program the EPCQ4A device with the old .pof file which i used for EPCS1.
I am using Quartus prime 18.0 lite version, USB Blaster Rev.C cable.
Thanks & Regards,
Radha.P
