8 years agoHow to program EPCQ4ASI8N for an old Cyclone FPGA
Hi, Is there a way I can program a EPCQ4ASI8N to work with Cyclone I? I have to keep some products which still use Cyclone I FPGA with EPCS4SI8N. Due to EPCS4SI8N discontinuation, ...
8 years ago --- Quote Start --- Hi, Is there a way I can program a EPCQ4ASI8N to work with Cyclone I? I have to keep some products which still use Cyclone I FPGA with EPCS4SI8N. Due to EPCS4SI8N discontinuation, the EPCQ4ASI8N might be a possible alternative, as advised in PDN1708. My problem is that the Cyclone 1 was supported until the Quartus 10.1 version, and the support for the EPCQ4ASI8N begins from Quartus 17.1. I thought that the solution would be just to take de .pof file, generated by Quartus 10.1, and just program the new device EPCQ4ASI8N with the Quartus 17.1 programer, but I got the following message from Quartus 17.1 programer when I tried to change de device to EPCQ4A: "Device EPCQ4A selected for replacement is incompatible with target device EPCS4 associated with programming file..." So I don´t know how to generate the .pof in the old Quartus 10.1 since it does not support EPCQ4A yet. Is there a better way to do that? --- Quote End --- If you still have Quartus 10.1, you can try two things with the Quartus 10.1: 1. Use your existing .pof file and program the EPCQ4A using the 10.1 programmer 2. Generate a new .pof file in the 10.1 programmer for the EPCQ4 flash (without A) and try programming the EPCQ4A device
