18 years agoHow to make a NULL FPGA (CycloneII) - a complete empty design
I am trying to make a FPGA design that behaves just like an unconfigured FPGA - from a boundary scan point of view. Why ? we test boards with Boundary scan ,and factory new boards with empty flash...
18 years agoMay be the pins are driving out, cause you set them to inout without setting 'Z' output state. I did'nt understand, why you defined the port pins at all. They aren't needed for a blank design.
I have e. g. a blank SFL design, it uses no port pins (apart from internal defined ASMI pins). In this case, the ununsed pins setting has to be input tristated or similar. But I think, you could also force outputs in BSDL, so I don't actually understand, how BSDL functionality can be blocked by a configuration
