13 years agoHow to install SD Card and ethernet at uClinux
I have just installed uCLinux at Altera DE2-115 (FPGA BOARD), I have full access to the terminal, the things that happen:I want to set an IP and also MASK for my eth0, when I do "ifconfig" it only sh...
13 years agoThe Problem Persists, also it has made it worse, after I remade the zImage I can't get nios2-terminal poped up once again, it gets stuck at this:
nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [5-1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
